Cowie
After wintering the boat the engine turns 180 degrees and wont turn further when trying to starting it. Thoughts are sticking valve engine make Volvo D1-13.
Much appreciated on the feed back I fear it maybe something deeper but will remove the injectors.Better to pose this sort of question on the PBO forum as you get a much wider audience including people who know about engines.
However probably need more information as if the engine will not turn over it is likely to be far more than a stuck valve. To check whether it is seized you need to remove the injectors and see if it turns over by hand - with a spanner on the pulley nut.
Keep you posted
Yep, exhaust problems as well cooling so forth alll good now apprecatie the feed back,Water in a cylinder causing a hydraulic lock?
