Trailer paint recommendations
Avocet
3 Jun 2001
Cumbria
I have a big, old and very rusty trailer that I'm rebuilding. It's not a boat trailer, but I suppose it could carry a small boat! It's entirely open section steel (angle and channel only) so I don't have to worry about internal cavities. At present it's almost entirely back to bare (but rusty) metal. Bashing it with a big hammer gets the big loose flakes off but there is, of course, some powdery surface rust under that. Any recommendations for paint? Hammerite? POR 15? Something with some zinc in it followed by something else? All suggestions gratefully received!
VicS
13 Jul 2002
Before painting it get rid of all the rust. Blasting is the ideal way.
Otherwise chip, scrape, wire brush and use a chemical rust remover or converter.
My trailer is painted with Hammerite, but IIRC on top of an iron oxide primer. No great love of the stuff... our paint lab at work tested it once and pretty well rubbished it.
Since Nigel was in short trousers (and the paint labs tests) the formulation of Hammerite has changed a couple of times at least, and it seems not for the better.
Gordonmc
19 Sep 2001
Loch Riddon for Summer
Bash off any loose flaking rust with a slag hammer, then give it two coats of Zinga:
http://www.zinga-uk.com/
Then cover with a paint of choice. I would not bother with Hammerite which is not the same since the brand was sold off by Finnigans.
The instructions for Zinga say don't apply to clean metal... it likes a thin coat of rust.
sailorman
21 May 2003
Here or thertemp ashore
Our old boatyard owner painted everything & i mean everything with grey danboline, he swore by it
Avocet
3 Jun 2001
Cumbria
That Zinga looks the business! That said, the application guide seems to make a big deal of having the substrate "completely" free of rust. Bashing off the loose stuff and attacking with a wire brush is something I can do, but I won't be able to get all the rust off. Does that matter too much?
Lakesailor
15 Feb 2005
Near Here
The video shows them shot-blasting. Possibly not much good for the home DIYer.
That Vactan looks good.
William_H
28 Jul 2003
West Australia
My recommendation is for lots of old engine oil splashed in the corners especially and coat it often. For paint however I use a fishoil type paint made for galvanised steel. good luck olewill
tr7v8
30 Nov 2001
Kent
I used to use Hammerite a lot, but it chips badly. I've now started to use Rustoleum which is miles better.
seanfoster
5 Jan 2006
Nottinghamshire
I recently built a trailer for a 26ft yacht from scratch and as I had spent a lot of time, effort and money on it decided to get it galvanised.
I thought it would be pricey but went to an industrial galvanizers in sheffield (there's bound to be some near to you) and they did the whole lot (degrease, drilled any breather holes required and dipped) for only £100 +vat.
Might be a job to get it there in your case and would need it shotblasting first, but thought I'd give you another option!
Pic below before and after:
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
How old do you think I am? :)
Rust-oleum looks like good stuff: "Harmful if inhaled. May affect the brain or nervous system causing dizziness, headache or nausea. Harmful if swallowed. Causes eye irritation. Vapors irritating to eyes and respiratory tract. Combustible liquid and vapor.".
Proper paint, not for cissies!
http://www.rustoleum.com/CBGProductFinder.asp?pfm=RST&bsq=2&bid=6
Avocet
3 Jun 2001
Cumbria
Thanks all. Excellent looking trailer Sean!
Well, although I'd like to get it galvanised, that's just too much hassle / money at the moment. I liked the idea of that Zinga, but realistically, I know there will be little chance of me getting the surface that good and blasting would be pretty tricky to do well because of the shape. I've gone for some Rust-oleum because it seemed to be the most tolerant of an existing rusty surface and was pretty cheap, so I'll see how it goes. Must admit I'm a bit worried about theft, but I have a hitch lock and the drop sides are original (and look pretty rough), so that might be a sufficient deterrent.
lw395
16 May 2007
I think I would either spend the time getting it rust free, with blasting and some sort of phosphoric treatment, then carefully prime it etc etc, or just whack a bit of zinc based primer and a coat of gloss on.
A quick job to slow the rust down is better than nothin, but don't expect too much.
Thistle
2 Oct 2004
Here
As with almost all paint jobs, the time the finish will last is a direct function of the time, effort and care spent on the preparation stage. Skimp on that and you can look forward to re-doing the job sooner rather than later.
SHUG
18 Dec 2010
E Scotland
Wise words!!!!
Members online
No members online now.
