jstarmarine
As many of you know from following my other Thread on this forum, I have another restoration project underway at the same time. When I am unable to get up to Chance this yacht is where I spent my spare time when not repairing and restoring my clients boats and yachts
I am taking the time to work closer to home base and get on with my other restoration project Mai Star II. It has been standing in my Yard for the past few years with little being done to it apart from removing much of the rotten deck and broken deck beams.
The main job at the being of the project was to get rid of the worse of the rotten and broken parts, such as Broken foredeck deck beams. The two which had broken were the two just ahead of the cabin. These two beams were the original deck beams that were either side of the mast hole through the original deck.
Sometime in the past the lower part of the mast was removed and a steel support post was fitted under the deck to support a tabernacle. The base of which spanned the two deck beams. However, these deck beams broke with old age and now I have to make two more deck beams as well as a number of other deck beams and carlins around the boat.
Much of the inside of the hull is in reasonable condition apart from a few places where the fixings have become streched and the planks have move out of position and look like a clicker built boat on the inside as well as the outside especially on the turn of the bilge. This as possibly been to being grounded over the years and not using the boats beaching legs which original holes and backing pads can still be seen in place on the inside of the hull amidships.
The forward end of the hull on the port side is the worse affected with the most broken rids and damaged frames.
In this photo it can be seen that I will have to replace all the ribs and frames in this area to get the strength back in the hull, before tackling the ribs and frames further along the port side.
Deck leaks and lack of good ventilation made this area a breeding ground for the top of the frames to go rotten while the rest of the frame is in good order, therefore, it is going to be matter of renewing the top of the frames and making good the whole area around the top of the frames.
One job that was done early was to remove the whole of the top plank around the hull. It was find that just the top plank was affected and the rot had not go=ne further down the hull.
