ajay
When swapping a bow thruster has anyone any clever idea how to check for possible leaks before relaunch ?
I always used blue tack to test bilge pump operation.Just a thought - could you get hold of drain test plugs of the appropriate size, as that's the job they're designed for.
Thanks, was thinking of making up something like a drain test plug, its an odd size tunnel 132mm.Just a thought - could you get hold of drain test plugs of the appropriate size, as that's the job they're designed for.
Thanks, good idea, might try that, will have to block off the bilge tunnel to the next bilge then fill, if it all goes wrong it will just run into the next bilge anyway.Block off any drains to compartment and fill with water
Or jet wash outside to see if any water leaks in
