Bigguns21
Hi, I've seen some control systems for airdeck dinghy, can anyone point me in the right direction please
Never seen what you describe. I really can't see how it can be achieved. Please let us know what you find.Hi, I've seen some control systems for airdeck dinghy, can anyone point me in the right direction please
yes hence the "closest". I have seen pictures of a tube mounted system but can't find anyone selling it.Lots of similar systems, but they nearly all require bolting down to an aluminium floor, so wouldn't work with an airdeck.
Can't see the need for a console steering position on an inflatable boat that size , as visibility will not be compromised at the tiller at any speed. The point of a console on bigger ribs is to raise the driver's point of view above the bow which would otherwise be out of sight at speed. Sitting up high on a 2.70m dinghy might also involve stability issues.
Your showing a photo of a rib not an airdeck. Its a completely different solutionThere's loads of small boats around with consols, I've pretty much found what I'm after, just all separate, was only after it as a kit cheers guys
The floor are different obviously, but your saying its pointless because of the length? So I showed you a boat 200mm longer then mine with that on? Either way, I wasn't asking to be told not to do it, I'm asking if someone has seen a kit for it, if you haven't then don't comment, simple!Your showing a photo of a rib not an airdeck. Its a completely different solution
So if you want a kit for an airdeck why post a photo of a rib with a totally different solution? I wasnt telling you not to do it. I was pointing out that it is a totally different solution.The floor are different obviously, but your saying its pointless because of the length? So I showed you a boat 200mm longer then mine with that on? Either way, I wasn't asking to be told not to do it, I'm asking if someone has seen a kit for it, if you haven't then don't comment, simple!
FYI there's a ton of sites showing you how to attach the frame to a piece of marine ply, like I said, I know how to do it, just need the kit
