Madhatter
What are the advantages (if any) of having a steel boat rather than fibreglass please ?
More likely to survive contact with rocks
Tough, relatively easy to repair, "cheap" (possibly) to build, flexibility of construction allows one offs and unusual designs.
Attractive in some applications such as canal boats (tin boxes filled with the contents of a bedsit), long distance sailers, particularly those cruising in areas where there are lots of rock or coral to hit.
Dowsides, maintenance, looks (some), weight, interfaces with other building materials (eg teak decks), condensation. Many of these can be reduced but at a cost which makes well built steel boats more expensive than GRP.
Clearly benefits are not appreciated by many people as they represent only a tiny minority of boats built except in the two categories suggested above where arguably their advantages outweigh the disadvantages.
For me the ideal expedition type boat material is Strongall. Super thick aluminium.
The problem with thin aluminium boats (say 4mm, density of 2.65) is that they are very difficult to weld and welding faults if any, are not picked up by radiography or ultrasound tests..
Steel with a density of 7.85 is easy to weld but rusts.
With Strongall, which is 2.5 to 3 times thicker than traditional aluminium, welding is no problem; they support a very high intensity of current which would melt traditional thin aluminium, and does not lead to hull deformation. The hulls are sand-blasted and zinc-ed inorganically with silicate which renders them free from electrolysis.
These hulls are as strong as steel but are virtually maintenance free. They also give rise to hulls which are so solid they don’t need internal bulkheads – which frees up internal layout possibilities.
(Facts picked up from a communiqué from Michel Joubert (architect) and Chantiers Meta the patent holders.)
The principal disadvantage is that you can not have round hulls.
I would like to thank you all for your contributions it has been most helpful.
For those that are interested I have been looking at a Dennis Ganley designed Hitchhiker 27 ft , looks like a tough little boat.
They will survive a lightning strike.
We had a steel yacht for a few years, but the constant maintenance became too much for us and we went back to GRP.
A friend who has a steel 30 footer says that steel is the same level / commitment to maintenance as wood.
However the strike may turn your boat into a powerful magnet rendering all compasses useless. Ask me how I know this.
