Lakesailor
Following my proposal for the mainsheet on my dayboat, and Bilbo's alternative, I went with his idea of fitting it to the floor-bearer.
A bit of angle iron was drilled and painted in galvanising primer. I've used it before on my trials car and it works well without a top coat.
I loosely fitted it with some grp and glass paste behind it to form a proper bearing surface.
Then a U-bolt through a bit of floor ply (epoxy coated and varnished)
The floor boards are cut to fit around the u-bolt (the floor boards are removable)
Yes, I know the grain runs the other way. I thought it better than risking a bad match of grain.
I've yet to try it out, but that is rock solid. I am almost sure you could lift the boat with it.
