Seafarer Mark III blown capacitor
rptb1
18 Sep 2013
Cambridge
tammynorie.wordpress.com
I'm helping to fix up an old boat which has a Seafarer Mark III depth sounder. It was probably working a few years ago, but is dead to the world now. Electrolytic capacitor C1 on the board has decayed and likely exploded (see photo). Can anyone tell me what capacity it had?
What I'd *really* like is a copy of the circuit diagram.
TernVI
8 Jul 2020
The usual way to blow up an electrolytic is to reverse the supply volts.
They are rarely close tolerance parts, often used for supply rails, anything of suitable voltage might work.
It's C1 and right next to ZD1, which is odds-on a simple regulator circuit near the power supply.
The cap being absent is unlikely to stop the unit functioning, if powered from a clean supply.
rptb1
18 Sep 2013
Cambridge
Indeed, though very old ones (e.g. in early 1980s micros that I have fixed) dry out and explode even with the current in the right direction. It is possible that the previous owner did something dodgy with the battery though.
Yes, I think that's likely. I can likely guess a reasonable capacity just from the size.
It shows no life when powered from a clean 12V supply on its labelled 12V inputs.
The photo was taken by a friend, and I haven't got my hands on it yet. We'll get it on a bench and have a close look, but not today. That's why a circuit diagram would help.
I have the instruction book complete with circuit diagram., but it does not give any component values
If nobody helps maybe I can photocopy or photograph it later but after this morning I will be away from home for the rest of the week living it up to celebrate "stage 3"
penfold
25 Aug 2003
On the Clyde
Given the huge hole in the heat sink it's probably had a battery leak corrosive ooze everywhere; is it really worth spending time on? An advert in the wanted section might turn one up, or post a message on one of the facebook groups for old boat gear. Here's one on ebay.
savageseadog
19 Jun 2005
The "+" mark shows it to be an electrolytic capacitor. I would suggest the value to be non critical perhaps 10-100uF
JohnGC
21 Oct 2011
Plymouth
Some of the text on the old capacitor wrapping is still readable. Might be worth giving it a gentle wipe and examining with a magnifying glass.
Nick Barnes
20 May 2021
The unit had a PP9 battery in it, dead but clean and intact, when we first opened it. And aside from that hole, the innards are pretty clean - very little residue. So I suspect that it has been cleaned up, and functioned OK, since the leak of some previous PP9.
Nick Barnes
20 May 2021
We had a go at this. Capacitance sadly illegible, and the wrapping basically disintegrated to the touch.
rptb1
18 Sep 2013
Cambridge
We bought the unit from eBay and it appears to work. The capacitor C1 is 10µF in that unit. I will try to revive the old one at some point and will update here if we get anywhere, but it may be a while. We have a lot to do to get this boat launched!
andsarkit
27 Aug 2015
Dartmouth
25V 10uF the same as the other 3 on the board. Black band is towards the outside of the case.
I still have the original mk3 from my boat and I have just powered it up and it appears to work - it must be over 50 years old. I get a reading in air bouncing off the wall which appears correct allowing for the difference in speed of sound in air and water.
If you are interested in keeping old electronics going you are welcome to it plus a spare unused transducer for the cost of a donation to your charity of choice. PM me if you want it.
