tridentwarrior
I have a ProTech 1230i plus charger that suddenly died. Having over 40 years experience of working in electronics I took a look inside.
I have found the faults namely an open circuit primary winding on a transformer (T1) that caused a transistor (VT2) to short circuit, this in turn blew a resistor (R9) literally to pieces. However, I was able to recover and measure a piece of this, I calculated its total resistance to be about 47ohms.
I was able to substitute a resistor, an equivalant transistor and input a low subsitute voltage (6 volts ac) from another transformer. These test measures allowed the charger to boot and function, apparently correctly.
When I contacted the manufacturer in the USA for actual component details or a circuit diagram they were, shall I say "unhelpful" replying with the comment;
"this is proprietary information which I am not at liberty to release".
Can anyone help me ? What I need to know above all is the value in ohms of resistor R9. If the colour coded rings on the device may mean nothing to anyone looking at R9 no matter just tell me what they are in sequence, left to right or right to left or both and I will decode them.
It is likely that the ProTech models 1220i and 1240i use the same values components.
If anyone knows the secondary output voltage of T1 that would be great too.
If anyone out there could help with these answers that would be absolutely fanastic.
All the very best,
Trident Warrior
All the very best,
Trident Warrior
