Overheating issue…
OceanRipples
14 Aug 2020
Hi, I have just purchased a boat with a 4.3L LX Merceuiser V6 (petrol). I’ve done a sea trial in the boat and everything was fine. I’ve just run up the boat on the driveway using a hose and earmuffs, which seemed to seal well around the leg, and after five minutes or so running I had to turn off the engine because the water temperature was v high. Does anyone know why this has occurred? It’s almost as though the thermostat did not open, although I can’t imagine that’s the problem as it was fine one week ago. Is there an inherent issue of engine overheating when using earmuffs on a hosepipe? Image attached. Water did seem to be coming out of the leg, so it was definitely getting a level of cooling going though. Does anyone even know where I can locate the thermostat? F11440CB-81DC-4C21-BD96-2A219481F2C3.jpeg
BruceK
8 Feb 2015
Conwy
here:
Also see the checkballs. If they are loose then overheating at idle can be a problem
Also check when your thermostat opens. IIRC should be at 140F/60C. Quite low as thermostats go.
OceanRipples
14 Aug 2020
here:
Thank you! Out of interest what do those balls do? When you say check they are not loose, do you mean that they don’t slide up and down the rod? Also, how do I check/know when the thermostat has opened?
BruceK
8 Feb 2015
Conwy
difficult if you dont have a thermometer for it. Just replace with one for your engine from a dealer.
Control waterflow on bypass
Types of thermostat housing depend on age of engine (note there are various grades of thermostat so check with dealer which one your engine should open at)
knock yourself out.......................
OceanRipples
14 Aug 2020
Thank you, super helpful links also, thanks a lot!
oldgit
6 Nov 2001
Medway
When were the risers last replaced/checked.
Check risers next ? Not that difficult a job and needs to be done out of the water.
Traces of rust around the riser to engine block connection , a warning sign.
The four bolts can be a pig to get at as well. heat and lots of release fluid will help.
OceanRipples
14 Aug 2020
Thanks!
OceanRipples
14 Aug 2020
If everything ran fine on sea trail it could just be lack of water flow via the hose route for sure
Thank you, the more I talk to people I get the impression that is the case, I simply isn’t enough water and pressure to circulate the engine properly. These ear-muffs are clearly just for rinsing briefly.
stelican
25 Nov 2004
fareham hampshire
You can normally run engine on muffs for extended periods if they are a good fit.I have done this many times.
AndieMac
24 Mar 2009
Tasmania, Australia
They do need to be double sided muffs on a bigger engine though.
Yes, agree with this comment, with a good tight fit around the intake strainer, good water pressure of course the engine running at idle revs only.
I’ve seen cases where the unsuspecting operator wanders off allowing the rinsing process to run its course, and the weight of the hose pipe coming up from the ground on loose fitting muffs (or an imperfect push-on hose fitting), and water pressure, drag the muffs away from the outdrive and an overheat develops.
I used to run the hose pipe up behind the trim tab rams then down to the strainer/inlet and muffs, to support the weight of the hose where it connects to the muffs.
OceanRipples
14 Aug 2020
The pressure is good on our hose and the fit is tight but still leaks out the muffs due to the pressure of the water. I have the double sided inlet muffs. See attached. Yes, I imagine walking off and leaving this is not a good practice! ?
