NASA Electromagnetic Log
nickcole
20 Aug 2006
Cornwall
Hi - Last winter I installed the NASA Electromagnetic Log transducer and connected it to the Raymarine ST60+ display. NASA state that their transducer will work with any compatible NMEA 0183 display but it's not working. The display shows " - - - - ". The NASA controller NMEA light flashes, indicating that the signal output is okay. Am I missing a trick here?
pvb
The Nasa transducer outputs NMEA0183 sentences VHW and VLW. What sentences does the ST60+ require?
dolabriform
12 Sep 2016
London / Suffolk
Which ST60+ Display do you have?
nickcole
20 Aug 2006
Cornwall
Not known - perhaps someone can advise..?
[/QUOTE]
nickcole
20 Aug 2006
Cornwall
Good questions. I naively thought I could just swap the old paddlewheel transducer for the electromagnetic one - based on my understanding that the NASA control box provided the necessary compatible output. For clarification I have a Raymarine SeaTalk ST60+ network of instruments.
I'll be on the boat in a few days so I can make further investigations regarding the current set-up. Anything else I should check?
pvb
I don't think you'll get it to work without a lot of messing about. Your easiest/cheapest solution would be to buy the matching Nasa display head for £85.
earlybird
18 Aug 2004
Cumbria; U.K.
There might be a further complication. The Tridata needs the paddlewheel transducer connected to it, otherwise it acts as a repeater for Seatalk. This will be OK for speed etc. if you connect a NMEA converter but you might lose your existing depth data since the display won't be able to act simultaneously as master for depth and repeater for log/speed.
Take PVB's advice.
cpedw
1 Jun 2001
Oban
Take PVB's advice.
I think the Tridata allows depth and speed master/repeater to be set independently. But without NMEA to Seatalk it's no help.
duncan99210
29 Jul 2009
The OP has a network of ST 60 instruments, presumably linked by Seatalk. All he needs is to find one of the instruments with a vacant set of NMEA IN terminals, link the transducer output to that and that should work. IIRC there are a number of the ST60 series that have a set of NMEA IN terminals, anyone of them should do, including the autopilot computer/control head.
earlybird
18 Aug 2004
Cumbria; U.K.
Not necessarily. For instance, my ST60 Graphic, which is a fairly general purpose repeater, does not recognise the NASA NMEA VHW and VLW according to the manual that I have.
dolabriform
12 Sep 2016
London / Suffolk
Looks like the Smart Pilot will accept the VHW sentence, but not the VLW sentence.
Two options I can think of,
1) Raymarine E85001
2) The ST60+ Multi display that I have sitting around and might be looking to sell. This will convert NMEA to Seatalk but I can't remember off the top of my head if it supports the needed ones
