Yngmar
I've made a thing. It's a very low cost barometric sensor that outputs NMEA 0183 barometric pressure (and temperature) sentences on a USB-serial interface (should be trivial to modify with an actual serial output, if you need that). Plug it into a computer with OpenCPN and you get a barograph (barometric pressure over time). Components should cost under £10 and you only need to solder together 4 wires and do a simple firmware upload. Maybe stick it in a plastic box.
If you're interested, I've written about it here and made the source code and instructions available for free.
