Refueler
While lowering mast for this winter storage - we missed fact that the mast foot pivot was frozen. As mast pivoted do9wn into the Y cradle - the mast foot shattered round the pivot bolt.
The foot item is of course the old style cast alloy type and its been passed to local specialist Metal Workshop - they consider the item to be old age and not likely to be strong repair. They have suggested cutting away a larger section, create new and mill to shape / requirements.
To be honest - I am also not so sure a repair would be strong enough as I only do mast up / down using that pivot .. I have 3 bridges to negotiate from my home mooring to get to baltic. If I was using vertical lifts - then it would not be such a concern.
This is the section they advise to cut away and replace :
If I can source a replacement - that would be best .. 2nd hand or even new if available.
If anyone has such an item - first of course we'd need to check dimensions - so please can you measure it at various angles / lines to see if it fits ?
Prefer obviously UK or EU sourced as shipping such a heavy item is going to be an issue.
For anyone not familiar with such a mast mount :
