Channel Sailor
I have been looking more closely at my pole topping lift line which is looking rather worn. It looks to be a little spindly (8mm) considering the load sometimes on it. It is a 43squ m area downwind type spinnaker, Fractional When well downwind I have the pole usually at 90 degrees to the mast so load on the topping lift appears OK. The theory I have read is to try and keep the pole level with the sea/horizon, which I get for well downwind. But for a Reach should something different apply?
But for a Reach I usually lower the pole outboard end to create a straighter luff, but keep the inboard end high enough to keep the tack very close to the forestay. This means the pole is certainly not level with the sea/horizon. Also the topping lift load seems quite high. My questions are, when on a Reach and the wind increases to say upper F2 or more if still OK:-
should I level the pole (in a low position both ends)? This reduces the load on the topping lift. Or for Reaching should I up the strength of the pole topping lift? I do have a strong 2:1 pole downhaul on a bridle.
Is there a technique to ease the compression load on a spinnaker pole so the deck crew can move it safely without it being either stuck, or risk of it quickly slipping uncontrolled up or down the mast track.? Is it simply a big ease on the sheet and a lot of flapping for a few seconds, which is tricky if Solo.
should the backstay always be on hard when Reaching with spinnaker? This to help protect the mast from bending aft in the middle.
