send54sail
I have a newish (less than 12 months old) Jabsco macerator pump 18590 – 2092 (12 volt). Its the 3rd or 4th one I have bought in the last 6 years so I was under no illusions about the disgraceful quality of these products, despite the high price (and forums are full of caustic comments about them), but I wonder if anybody has come across the following issue?
First, the macerator has not successfully emptied the holding tank on the last couple of times that I have attempted to use it (even though the motor ran as usual, and sounded normal), so yesterday I decided to check what the problem was.
Before taking anything apart, the first thing I did was to get the holding tank emptied out at a boat pump-out facility at the marina so that I could inspect the macerator without the contents of the holding tank spilling out. However, when I opened up the lid to the holding tank itself (which had only just a few minutes earlier been completely emptied at the pump-out) I found the holding tank was filling up very fast with sea water. I then shut the seacock straightaway (which obviously I would have done before removing any hoses, but hadn't expected any drama just from lifting he holding tank lid).
To double check, with the seacock closed, I then removed the hose from the inlet side of the macerator (i.e. exposing the 1 1/2 ” plastic "hose tail" piece on the end of the macerator that the hose is clipped to that connects the macerator to the holding tank). When I then allowed the seacock to open for a few moments with that hose removed, seawater again poured out of that inlet side of the macerator.
I realise now that, not only had the macerator not been working to pump the holding tank out, but, much more dangerously, seawater in the outlet pipe (i.e. the 1” hose that connects the macerator the seacock) was actually being allowed to pass through into the “holding tank-end” of the pump. This means that it was only the tight lid on the holding tank that prevented the boat from being flooded (and sunk). Obviously, the macerator should not allow water to pass in the direction from “seacock-end” to “holding tank-end” – it should only allow flow in the opposite direction.
If I had left the boat for an extended period then there would have been constant flow of seawater into systems (ie. the holding tank itself) which are not designed to deal with seawater coming in under pressure and inevitably the boat would have been at risk of sinking.
Any thoughts on this situation gratefully received - including any different brand to replace the Jabsco macerator pump 18590 – 2092.
Cheers
Andy
Cheers
Andy
