Identify this hull?
JimmusUK
28 Mar 2020
Worthing, UK
Hey,
Still searching for the right boat.
Can anyone identify this hull, owner has no idea.
Jim
BruceK
8 Feb 2015
Conwy
The cathedral hull was very popular amongst small fast fishers it could be just about anything. To me it also resembles a CJR 14
Davy_S
31 Jan 2003
in limbo at the mo.
The CJR was a triple hull, the central keel was not as deep as the seahog, CJR photo.
Davy_S
31 Jan 2003
in limbo at the mo.
Excellent, thanks for your help. Any ideas how good a seahog is as a fishing platform. Can it cope in a bit of chop offshore?
The Seahog hull is a good sea fishing boat, it is stable at anchor, yes, it can cope in a chop, but bear in mind, it is a small boat and should be used in suitable weather, it is ok in a following sea or a head sea, the CJR on the other hand, is stable at anchor, good in a following sea, but slams badly into a head sea, it can suffer lots of stress cracks as a result. I have had both boats.
JimmusUK
28 Mar 2020
Worthing, UK
Do you think the small protruding v at the center of the catherdral will reduce the slamming a little? I used to have a little bayliner bowrider which slammed pretty bad and that had quite a big v at the front if I remember.
Davy_S
31 Jan 2003
in limbo at the mo.
The protruding V helps to reduce slamming when compared with the triple hull of the CJR, you have to compromise with small fast fishing boats, the best hull shape would be a deep V, but this would need a bigger engine to get it up on the plane, plus it would not be as stable when anchored, it would roll more when you moved to one side, a cathedral hull tries to get the best of both worlds, easy to get up on the plane, but stable at anchor, they will all slam in a head sea to some extent, you simply have to slow down to suit the conditions.
JimmusUK
28 Mar 2020
Worthing, UK
Great, thanks for your help.
I've put a deposit down on this little boat and will eagerly await the lifting of the travel ban!
I'd like to start ordering the items I need to kit her out inc. a cover. Any advice for if you had this type of boat?
