GGR 22
jlavery
25 Oct 2020
Simon also mentioned weather forecasts. He's just about picking up forecasts from the NZ chap (name escapes me) on the radio, but competitors closer to NZ are relaying them to others.
Also the Brazilian forecasts are not much good (as he commented on the way down), as all they seem to be doing is reading from the routing/weather books!
garymalmgren
28 Jan 2017
whether Simon had managed to fix his broken "Hitchkers Guide To The Galaxy" cassette tape!
What no back up book?
Don't Panic!
Goldie
29 Sep 2001
Nr Falmouth, Cornwall.
… abit more info on steering failure. His and Hydrovane's expectation was that the vane would/should have failed sacrificially, rather than the casting.
Please can anyone point me in the direction of info as to what actually failed? Was it the big, main casting? I have a Hydrovane on my current boat hence the interest. Incidentally, my previous boat (for 40k nm) was a Biscay 36 but had a Monitor vane gear.
jlavery
25 Oct 2020
My understanding is that yes, it was the main casting. Simon had taken lots of spare stuff, but there's a limit to what you take (i.e. a spare mast at the extreme). If I remember correctly, his conversations with Hydrovane went along the lines of "haven't seen that before."
As previously mentioned, the expectation is/was that the vane itself would break off/fail before the casting.
Goldie
29 Sep 2001
Thanks. At least there are two mitigations for me: 1, I have no plans to be in the S. Ocean and 2, at least I have an autopilot as back-up!
Blueboatman
10 Jul 2005
The early Monitors were no strangers to failure either btw..
Using lower grade stainless steel and subject to cracks and weld failures through crevice corrosion. One or two owners just junked the whole frame for a new frame.
I look forward to seeing the really clear photos of the ‘deconstructed ‘Hydrovane casting ..
Kola
4 Dec 2018
Simon Curwen Hydrovane failure 27-1-2023
zoidberg
12 Nov 2016
Having looked at the above photo-pics, I don't think that's quite the job for Loctite Threadlocker.
Perhaps JB Weld for Steel might have managed.
What does the hive-mind think?
Slowboat35
4 Apr 2020
Bizarre - why are Watt & Sea hydro generators allowed, as they are hardly original 60s tech? And indeed, why are they needed with so few electronics permitted.
The “rules” seem more and more illogical.
I see nothing illogical in that. It's the device type that's frozen in time, not the individual model or else they'd all be condemned to using RT144 radios, rotating 'echo sounders', BMC engines and rubber-cased Exide batteries. Towed/demountable generators were evidently around at the time and so are permitted now.
zoidberg
12 Nov 2016
Ian Herbert-Jones has survived the night to the SW of Cape Horn - and an especially wild one, with gusts to 90 knots, drogue entangled, hand steering, bare poles..... and sea state beyond description.
He made a call to GGR Ops at about 0400hrs as a 'SitRep' and to let the world know he was having a hard time.
At 1000UTC he was trundling along at just over 2 knots, probably with his drogue still out and trying to get some rest.
zoidberg
12 Nov 2016
In conversation with Angus Coleman a couple of months back, who is the 'guru' behind 'Ocean Brake' of Portland who supplies the Jordan Series Drogue, he mentioned he'd heard a couple of tales of JSD bridles snagging on windvane paddles - or 'rudders' if Hydrovane.
We discussed contributory factors and possible solutions, and agreed it is not desirable to complicate the system. However, this latest 'happening' has caused me to think again about the idea of using one - or two - lines from the boat back to the 'Triple Point' where the bridles connect to the leader-part of the main rode. One of these is thought desirable to facilitate hauling the rode in for recovery by winch.
I mused about having TWO of these, each wound a couple of times spirally around its bridle-leg and each having its 'inboard end' fed through a couple of fishing pole ferrules whipped onto a 5-6' length of 5mm, say, grp rod and tied off. Such 'rods' could be secured to the corner-legs of the pushpit such that they acted to lift the bridle-legs clear of the sea - like a fishing rod with a fish on the line - when the big loads relaxed and there was some danger of a loose loop of bridle-leg snagging an auxiliary rudder or paddle.
That's NOT keeping the system simple, I agree, but we are in the seamanlike business of spotting problems and trying solutions until we have something that works for us.
Comment is welcome.
zoidberg
12 Nov 2016
Looks like Ian H-J is having some 'time out' up a creek in the entrance to the Beagle Channel, 'just chillin'....
Isla Picton.....
zoidberg
12 Nov 2016
Ian H-J is still up his creek without a paddle, while Kirsten, Abhilash and Simon similarly are 'sitting in the sun' going nowhere fast.
