scr0che
Hi,
Been reading around on wiring/fusing for solar panels. I understand the need to put a fuse between the controller and the batteries, but is one needed between the solar panels and the controller? The reason I ask is because Renogy suggest it is needed as per this article - albeit it's quite old, but I've not read that requirement anywhere else:
How to Fuse your Solar System
I currently have a Victron MPPT 100/30 smart controller connected to a 30A breaker, then on to the battery which is right next to it. Planning to use 6mm cable from the panels (2x 175w) connected in parallel via a branch down to the controller, a run of ~5m. Is a circuit breaker needed there?
Steve...
Steve...
