Dino
Hi, I was wondering if anyone has any tips or tricks for cleaning diesel tank vent pipes. When I fill my diesel tanks the fillers back up and turn into a mini volcano of diesel. It happens in the last 1/4 when the tank is nearly full. I hear a gurgling noise and a few seconds later iget a projectile out of the fillers.
I have had a look for the vent pipes and they are copper pipes connected to the top of the tank. Do not very easy to disconnect and blow out.
The access to the skin fitting end seems difficult if not impossible.
I was thinking of opening the filler cap and getting a vacuum cleaner with a small nozzle to try to vacuum out any debris. The skin fitting vent is a shiny cylinder with two small holes at the bottom.
Would it help if I used a collar around the nozzle to block air exiting the filler? Or is that a bad idea?
