Failed to remove the shaft coupling
fisherman
2 Dec 2005
Far S. Cornwall
Use the gearbox flange, it's held on with a nut so not going to affect the G/B, not going to push the gearbox shaft out. basically it provides a robust puller, put a spacer on the shaft end, four bolts through the flanges, oil on the nuts and washers ,and wind up. You are only pressing the halves together, no endways pressure on the gearbox, as long as you don't start with the hammer.
Hurricane
11 Nov 2005
Sant Carles de la Ràpita
The OP said above that he doesn't want to risk damaging the gearbox flange.
I think his current approach is to do the same as you are suggesting but with a steel plate/disc instead of the gearbox flange.
fisherman
2 Dec 2005
Far S. Cornwall
OK. Can't see what damage would be possible. An old knackered flange would do for a puller.....
Mistroma
22 Feb 2009
Greece briefly then Scotland for rest of summer
www.mistroma.com
Yes, I spotted that. Perhaps he was under the impression that he was pulling on the flange. Most flanges are pretty thick and strong. I didn't even consider a puller with mine, just a spacer with longer bolts to squeeze the flanges together and some heat.
It is a puller, because it is pulling the coupling off the shaft. OP should think of it as a "pusher" because it is pushing the end of the shaft by applying compression between both flanges.
It was several miles to reach somewhere selling bolts and I decided to get a guy with the proper tools. Guess what, he used longer bolts, a steel billet and some heat. :D:D
Lucas Gan
5 Oct 2018
Yes. I just received some 120mm long bolts and just waiting for a piece of 20mm thick steel plate to do that. I will avoid using the gearbox flange because I don't want to damage it, and it's too little room between the gearbox and its flange. It is very hard to tighten the nuts there.
John100156
31 Oct 2007
SANT CARLES DE LA RAPITA
Just a thought, as 1.3/4" is so close to 45mm, could 'they' have possibly heated an 1.3/4 flange, and then fitted it to a slightly bigger 45mm shaft? Would make it blooming tight when cold, although I doubt it what with the key....
fisherman
2 Dec 2005
Far S. Cornwall
Get round that by putting bolts in from the shaft end, nut on g/b end, with an extra nut at the bolt head, which you wind in while holding the bolt head if needed. But it sounds like you are nearly there anyway.
  • Like
Reactions: vas
Falling Star
4 Mar 2011
Essex
I do wish you luck with it and hopefully that will work. Doing it that way, there is a risk that the threads may strip before it releases.
Take your time and maybe continue using heat and some taps with a hammer as you tighten the nuts.
burgundyben
28 Nov 2002
Niton Radio
I remember (many years ago) when I was rallying and rebuilding engines, we use to heat up the con-rods before pressing-in the gudgeon pins to assemble the pistons - not sure what the rate of expansion was...! :ROFLMAO:
You only need a few thou! Not half a millimetre!
Hole Expansion Ratio, HER, quite a complex set of calcs with a number of factors.
Bandit
30 Jun 2004
Guernsey
Its a British Fairline I am sure they are all inch and three quarter. Mine was and every Turbo 36 and Sedan I have seen is.
