Eberspatcher/Chinese heaters .......again .
clyst
18 Aug 2002
Hi all ,The Eberspatcher is having its annual tantrum again so I'm serious considering a Chinese replacement since they are becoming more reliable and cost effective now . Just looked on E bay and Amazon I'm surprised to see so many makes and models since they seem to have been fitted by many forumites anyone any recommendations ? Cheers .
Trident
21 Sep 2012
Somewhere, nowhere
They're probably all made in the same factory but with a hundred different resellers. I have two and two friends have one - all bought from different ebay sellers and all identical . No problems at all with them so far (mine are 18 months old) but I'd but a couple of spare glow plugs as they don't always last very long - but at £10 each they're not too expensive
oldgit
6 Nov 2001
Medway
£120 seems to be the average price and in the real world, the heaters will produce about 4-5 KW.
Should be enough for the average boat unless you want tropical temperatures.
Mine is the Planer 4K, adjust thermostat to 25C and it will get the boat up to about 22/23 C in all but sub zero temps.
Have never actually needed to run it flat out to date.
Worth taking note of the warnings about chinaspatcher silencers, in my case exhaust silencer was OK.
Simple job to connect new heater/fuel pump to old trunking/ fuel supply.
NormanS
10 Nov 2008
Eberspachers will run very happily on paraffin (kerosene). Mine has been burning exclusively kero for the past three years, at approximately 100 litres/year. Does anyone know if the Chinese or Russian copies can run on kero?
RumPunch
11 Jun 2014
Norfolk Broads
I have an all in one, in the cockpit, and ducted through the washboards. Totally removeable, fit it when I need it and stash it below when not. No need for separate diesel tanks, permanent fixture or skin fittings that way
Nauti Fox
28 Oct 2003
Kent
Ducatiproteam.co.uk
The Chinese heaters do, the one in work runs on white, red or Kero...whatever is around.
CLB
18 Jun 2013
I've run my chinaspacher exclusively on kero and am now on the third winter with zero probs so far.
Steve_N
31 May 2004
Fife
Same here - 2 chinaspachers running exclusively on kero and clocking up the hours.
I think it's only the genuine Autoterm Planar heaters that can't run on kero, a heating fuel.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
By Russian copy I assume you mean Autoterm Planar? In fact it is far from being a copy of any other make. Planars should not be run on kerosene, they run hotter than Eberspachers and will burn out. So my son tells me, he is the importer.
NormanS
10 Nov 2008
:D:D Does seem a bit strange. Thanks to you and CLB for the info. The diesel that I use on the boat is still the high sulfur stuff, and it gave serious problems with a deposit on the burner tube, - hence running on kero. Cheaper too.
PetiteFleur
29 Feb 2008
I have a Chinese heater which I installed last spring - I tested it for 20 hours with kerosene in my workshop and it worked perfectly. Now running on road diesel on the boat and still running well. I did choose the simple controller rather than the complicated controller where you can change the settings.
superheat6k
10 Jan 2012
South Coast
My Chinaspacher is very happy on Kerosene.
superheat6k
10 Jan 2012
South Coast
Chinaspacher....would anyone happen to be in a position to pm or post a link to a retailer of a unit that they are happy with, having run it for a long time
I recently did this on another thread but noted that one supplier I used had disappeared and the other was considerably more expensive. The Facebook group is probably a better place to find reliable suppliers, but someone else may be along soo to help.
CLB
18 Jun 2013
I bought in 2017 and am very happy, but the seller does not appear to be on eBay any longer, at least not under the same Name.
peteK
4 May 2009
Wirral
I bought a 2kw chinese diesel heater last year from aliexpress,tried to buy of ebay but was let down by million billion.Very pleased with it.
