Drascombe on the Thames.
st599
9 Jan 2006
I am intrigued, Do you drop your masts to pass under bridges, or just have a limited cruising range between bridges?
Many river boats rig a pulley on the forestay so you can drop the mast as you approach a bridge, then pull it back up afterwards. Some can even do it without needing to paddle if you get the speed up.
or if you're in a single hander, just lean it over.
