Sybarite
Anybody use them and how do they compare with a normal traveller arrangement?
(I have been looking at some boats which have them.)
What do you mean by double-ended?
You can splice the mainsheet to make it continuous, which is often done on boats using the German system with two winches.
Alternatively there are systems where both ends come into a jammer. You pull one end for a 6:1 or 8:1 ratio when trimming or both ends together for half that ratio, when you want the main in quickly, such as for gybing. I've only seen these on X-Yachts, but that's probably just coincidental.
Double ended main sheet and traveller. Just greedy really.
I have used a double-ended mainsheet and the biggest niggle is that you always seem to end up with all the slack at the wrong end. I currently have a double-ended main halyard and have to be careful not to end up with the slack at one end and the other with the stopper knot hard up against the clutch.
I sailed a boat with two mainsheets once.The sheets ran from blocka on either side of the coachroof, I thought it was woderful as it gave almost perfect control of boom position
Dont know but do you have some pictures of the set up from 2012?Is this a record for thread resurrection? ?
It's only 8 years old so relatively recent in resurrection terms.Is this a record for thread resurrection? ?
Se post #8 and scroll down.Dont know but do you have some pictures of the set up from 2012?
Thanks.Se post #8 and scroll down.
