Disolving old hard grease?
Vegable
4 Mar 2010
me : Pwllheli Boat : Arisaig
Having fought my way to the inside of my extreemly stiff hand anchor windlass, its full of old hard chunks of grease that's more like treacle toffee than grease. Parafin doesn't seem to do much. What's best to soften it and if at all possible flush the old grease away? It's removed from the boat and in my garage.
Mike
prv
29 Nov 2009
Diesel (basically the same as paraffin for this purpose I think) worked ok for me, but if you need something fiercer then perhaps acetone?
Pete
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
I've used all sorts, and nothing works 100%. So far, the best success has come from my brother using a degreaser for car parts, using caustic soda solution under pressure through a nozzle. The problem isn't where you can see the hard, brown varnish like deposit; it's where it is hidden inside things like roller bearings.
NormanS
10 Nov 2008
A hair drier would soften the old grease, then paraffin or diesel with a brush should wash it away.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Grease is always rather difficult to remove as it is a mixture of hydrocarbon oil and water-based soap. Modern soaps themselves tend to be rather insoluble in water. A lighter hydrocarbon solvent than paraffin or diesel may be found more effective for old, solidified grease. In the lab we would use hexane or heptane, the nearest equivalent outside being gasoline. A detergent solution should then remove whatever remains.
Vegable
4 Mar 2010
Thanks for your replies.
If grease contains soap, then will boiling the whole unit in a strong sugar soap solution in the wifes biggest pan work?
Mike
I reckon scrape and wipe away as much as possible , then wash of what will wash off with paraffin. Finally once you have removed them clean up the bearings themselves with gasoline but remembering its highly flammable nature.
Unless of course you happen to have a private stockpile of 1:1:1-TCE.
lpdsn
3 Apr 2009
Mike
A common trick with winches that are clogged up with hard grease is to liberally soak it in 3-in-1 oil or WD40, re-assemble them and use them for a short while, then disassemble again and clean as usual.
30boat
26 Oct 2001
Portugal
That's what I always do.WD40 makes short work of old grease.
I wouldn't use caustic soda anywhere near aluminium!!
Daydream believer
6 Oct 2012
Southminster, essex
Ha ha ha!
Yes! you might laugh, but as an experiment put some new grease on a tin lid. Hold it in some pliers & heat the tin with a blow lamp. I did & got the tin lid red hot & the grease did not have any visible change.
Old grease that has hardened will have done so due to some chemical reaction or addition of something ( dirt etc). Dissolving it in another chemical or boiling it in something is altering the structure of the grease so does not mean that the grease itself is being changed by heat only
Of course there are different types of grease ,& I am not suggesting you do this with your K Jelly etc. , but the usual high speed bearing engine grease does not always react as you might think. Many are specifically designed to be unaffected by a limited amount of heat
aquaplane
16 Sep 2006
West Yorkshire
www.utilitywarehouse.co.uk
If the grease is fat, animal fat, caustic would work as it turns the fat into soap, but I don't think we are asking about fat.
From personal experience cleaning up a car engine, acetone won't be effective on grease/oils either, it's too polar a solvent. Acetone is a very good solvent in some cases but this isn't one of them.
I would go for paraffin/diesel/petrol cold first but warm if possible. I can't see how you would safely warm petrol though. Paraffin and diesel have similar flashpoints at ~80°C but petrol will ignite at less than ambient so it's much more dangerous.
