Depth reading wrong
vas
21 Jun 2011
Volos-Athens
guess you came across this thread on arduino board:
Depth Ultrasonic Water Transducer
some specs are there, guess you ignore the issue on how you pump all that 600 or so W to the xducer and only focus on dealing with the return signal, which is going to be interesting if the pulse originates from the headunit (as it should be I gather) and then the headunit does the timekeeping and the calcs to see how long it takes for the signal to return.
Doesn't look v.straightforward tbh as you somehow have to grab the high pulse, start a timer, receive the return pulse, get the diff.
The rest is easy :rolleyes:
seems to be exceptionally hard (at least for my knowledge!)
Mind, could it be that the headunit failing to send the 600W pulse be the culprit?
Maybe open the headunit up and see how it looks inside? corrosion/water ingress/tired or damaged components, failing capacitors?
goodluck!
John the kiwi
23 Nov 2011
Nelson New Zealand
Speaking to Hudson marine, they’ve suggested siliconing a through-hull to the hull (no fancy liquid bath) as a temporary measure. Apparently should work, and if it doesn’t it’s because the hull’s too thick and an in hull wouldn’t have worked anyway. Anyone done this?
11 years ago i got a jar of vaseline and carefully scooped out a wadge(technical term). I sat the wadge on the inside of the hull and pushed the transducer into it. Its been there ever since and never failed. If i ever do want to remove it i have an easy cleanup job compared to Sikaflex!
The transducer was a cheap garmin unit designed for transom mount. Why make life more difficult than it needs to be?
Stemar
12 Sep 2001
Yes. On Jissel, the transponder was stuck to the hull with the Gosport pound shop's version of No More Nails for years. It worked fine through the best part of an inch of GRP. I understand that it might run out of puff to record deep water sooner than if fitted through the hull, but I'm far more interested in the depth when it's less than a couple of metres than when it's a couple of hundred.
laika
6 Apr 2011
London / Gosport
A coda to this...
So transducer it probably isn't as the new one showed the same behaviour as the old one. A new job has distracted me from thinking about info vas posted but something occurred to me. From Brighton to the Hamble the depth sounder seemed to spring to life occasionally and when the water was quite deep. The second leg it was better, mostly working in >12m. After testing it with the new transducer it seemed to be occasionally working >4-5m. hmm.. What was I doing between each of these "improvements"? plugging and unplugging the the connection between the head unit and the transducer, which is a two pin connector like those digikey seatalk 3 pin ones (which obviously the ST50s also have, but not relevant here..) but a bit bigger.
In post #4 refueler said check the connections. The pins on the male side were sparkly clean and the outside of the female looked clean but what had changed was plugging and unplugging and that points distinctly to a contact thing. So I ordered some contact cleaner, unplugged, and alternated twizzling a solid wire in the female side and blasts of contact cleaner.
Just checked and I currently seem to have a (believable) 3.6m. Still don't completely trust it and I need to go out sailing to check but this could be one of those 3 page threads that was answered in the 4th post. Plus I'm £100 down with a "spare" transducer
vas
21 Jun 2011
Volos-Athens
laika, silly Q have you actually checked that the male pins of the connector are not only clean but as long as they should be?
I'm asking as I just spent 3-4h sorting a no gps signal on a friend's GEONAV10in old plotter. After taking the whole thing apart, looking at the back of the socket turned out that one of the 7-8pins was pushed back into the device only making contact occasionally. Obvs sod's law makes that out of ALL the pins it wasn't the 5 unused ones, but the gps antenna nmea0183 + signal...
so check clean contacts but also make sure all pins are level.
In my friends case it was a matter of a slightly bent pin that in fitting the cable in a hurry pushed it hard and pin didn't "find" the hole, but was pushed back in the socket.
V.
laika
6 Apr 2011
London / Gosport
Are my male parts not only clean but as long as they should be?
That sounds like a very important question to answer and I'd hate to answer in the negative on either point.
The pins aren't noticeably bent or different sizes. I'll see how the depth reading goes this coming weekend but the contact cleaning seems to have made a difference. I don't completely trust it yet but readings were looking plausible on sunday.
bignick
10 Aug 2011
Poole
There are contacts at both ends of the Seatalk cables. have you got multiple Raymarine instruments on a Seatalk network? If so, you may need to check ALL the cables and connections. The ones at the head units, on the outside of the boat, can be even more prone to corrosion. You may have improved signal strength by cleaning the one on the back of the transducer, but the main problem may be somewhere else.
mattnj
26 Jul 2007
www.red-data.co.uk
Had this....was head unit...not a super easy circuit/pulse to replicate (unlike speed)
I do have an st40 bidata here for sale if interested.
laika
6 Apr 2011
London / Gosport
To follow up on this...I didn't cure the problem. contact cleaning seemed to make things better but that could have been my imagination. depth is fairly reliable where depth > 7-ish metres. On my marina berth in 3-5m it tends to vary by up to a metre up and down over the course of a minute, but in those depth while sailing I'll be seeing a constant 1.5 (0.8 plus my 0.7 offset). Sent the head unit to the service centre who reported no fault found but did incidentally tell me that 0.8 is the minimum depth this set up can show. So what's my next move? I don't know: I suppose it's back to the transducer. Maybe I hadn't dangled it far enough in the water in my last test
steve yates
16 Oct 2014
Benfleet, Essex/Keswick, Cumbria
Yes, i put a large dollop of silicone down and gently twisted the transducer down into it. Worked perfectly fine until i filled the locker with water by mistake.
david_bagshaw
5 Jun 2001
uk
My depth instrument (autohelm st50) has taken to mostly reading 1.5m, although it occasionally appears to show the right depth, especially in deeper water. The waterline offset is set to 0.7m and predictably with this set to 0 depth is .8m. We only came out of the yard last week so “something sticking out of the keel” is unlikely. The boat had been hardly used in nearly 2 years prior to that so the problem may have predated the yard trip. I’ve checked the connections and wiggling wires has no effect. Next step is anchoring somewhere to swim under the boat and maybe taking some wet and dry (used very wet) to the sensor but anyone seen this before or ideas about resolution? Having the boat lifted again to replace the sensor is going to be awkward
perhaps there is anti foul over it, there is a small chance a failed diode in the alternator could cause problems...
