Swanrad2
HI,
We neglected our Keel bolts. They became loose towards the end of the season and when bringing ashore the keel flexed cracking the gelcoat over a couple of square metres beneath the antifoul. So, I need to grind it back and have been watching videos and reading blogs for a few days but thought I would check my conclusions with the great hive mind.
1. I am intending to grind the gel-coat back to fibreglass (test grinds have revealed the cracks do not extend into the underlying laminate which is sound and not discoloured) one small section at a time, say 6 inches x 6 inches to catch all of the cracks. For this I think a flap wheel on an angle grinder seems to make most sense, done slowly and carefully so as not to grind too deeply into the glass.
2. Wash down with denatured alcohol.
3. Assuming no damage to any of the laminate I may lay on a couple of layers of bi-axial glass with epoxy resin to secure the substrate.
4. Sand back slightly and use gel-coat to 'bridge' between the high points to either side of the 'trench' I have ground out.
5. Repeat.
I have no experience of Epoxy based fillers, hence I'm reverting to gel coat. I own an angle grinder (but not a long nose sander that some of the videos seem to favour) so that seems to make sense.
Am I missing anything?
Cheers
5. Repeat.
Cheers
