Stabo
We intend to put coppercoat on our sailboat. Is it feasible to apply coppercoat also on propeller, shaft and P bracket? Any experiences with adhesion, in particular?
AMC suggest that putting Coppercoat on a prop may cause galvanic corrosion problems. I do not agree for two reasons. Firstly, pure copper is anodic to any likely prop materials, so if anything corrodes it will be the Coppercoat.Thanks to all for the answers!
I have very good experience with Velox system ( primer+AF), however intention is to reduce the lift-out as much as possible. For that reason the application of the coppercoat also to the propeller, shaft an P bracket is tempting.
May I ask Vyv, if there are some galvanic corrosion related issues to be considered or its more adhesion problem. Would epoxy wash primer ( as for instance Epifanes epoxy metal primer with zinc phosphate) help ?
I have seen this said several times but I cannot see why it should be the case. Small anodes corrode more quickly than big ones with a large cathode but that is never going to be the case here.If one coats a propeller with antifoul & the antifoul gets chipped in a particular area - ie the blade tip. I am told that if there is a situation where electrolytic corrosion is high- ie marinas etc- the prop could suffer isolated loss in a particular area. This can cause prop imbalance or damage to the prop.
This is why some suppliers prefer one NOT to apply antifoul paint to the prop.
I do not apply any finish to the prop & do not have a problem. However, I use the boat & it comes out of the water every year
Why don't you take the prop off and have it copper plated ! In the long run it is a lot cheaper
I'll try to get to the boat and photo the prop shaft and post it. Both prop and shaft were coated with Velox in the spring, as has been my practise for the last few years. The prop is clear but the shaft is covered with barnacles. Quite large, strong ones that are firmly stuck on.Not usually necessary to coat the propshaft as nothing much grows on that.
Very kind, tanks.Away from home now, will post copper plating info next week.
