Clipper duet
clyst
18 Aug 2002
Wanted clipper duet complete or seperate clipper depth and log complete units . Cheers Terry
captainboo
11 Dec 2008
Near Glasgow
I have a complete set available comprising of:-
1. Display Unit + mounting bracket
2. Cover + spare
3. Pizeo alarm (never used)
4. New unused log transducer
5. Unused through hull fitting for log + blanking cap
6. New unused Depth transducer + extra cable
7. Spare o-rings for log
The display unit was used up until last year and the transducers were acquired as spares but never used. The original depth is stuck in the boat and the log was modified for a different fitting hence the unused spares.
The cable for the depth transducer has been cut, still over 6m long to cut, but can easily be rejoined using standard TV coax connectors.
The log has a paddle wheel but it is showing corrosion on the magnets so would probably need replacing.
Have just tested in a bucket and under a running tap and all works!
How about £100 + postage at cost?
