She has been fully restored by her previous owner. However as you say they are a busy little craft and Richard ,(previous owner) is now 80 so decided to let her go.As said this is a National 12. A very long established development dinghy class, active Class association and fleets all over the country. I'm an ex-N12 owner (1980s) , lovely boat but it's not one for an old bloke like me (now)... You need to be agile and small.
Hope you plan to care for and sail her.
Gratuitous pics of mine, now sold. Tigress, N3127. What a lovely thing.
Replacing those clinker boards is a very specialised job and it’s certainly not a matter of just buying some replacements. The wood is planed and shaped to the correct size and thickness and may even have to be steamed to get it to bend and twist correctly.. A skilled shipwright would do the job. Are any of the ribs cracked or broken, because it’s important to steam new ribs in at the correct shape first. (Personally I don’t like the practice of doubling up on ribs although I appreciate it’s a cheap and simple way of repairing broken and cracked ribs in a clinker (or Carvel) hull.)She has been fully restored by her previous owner. However as you say they are a busy little craft and Richard ,(previous owner) is now 80 so decided to let her go.
Unfortunately the people who took her hadn't fixed hr to the trail correctly and caused some damage to the Hull.
Any ideas where I cold buy the ship lap boards for the Hull
Not sure what wood it is but its a very red ish timber
Stu
Hi John,Replacing those clinker boards is a very specialised job and it’s certainly not a matter of just buying some replacements. The wood is planed and shaped to the correct size and thickness and may even have to be steamed to get it to bend and twist correctly.. A skilled shipwright would do the job. Are any of the ribs cracked or broken, because it’s important to steam new ribs in at the correct shape first. (Personally I don’t like the practice of doubling up on ribs although I appreciate it’s a cheap and simple way of repairing broken and cracked ribs in a clinker (or Carvel) hull.)
if you want an idea of how specialised and intricate and accurate you have to be, try watching a few episodes of Tally Ho on YouTube. I appreciate its a boat that is of a completely different size in order of magnitude, but the principles are exactly the same. I also appreciate that Tally Ho is carvel, but if you watch the care with which Leo machines the boards when he planks up the hull you’ll see the accuracy that is required and you’ll also see how it’s not just a matter of buying in a plank of wood. Finally you’ll need some copper roves and fastenings and the right tools to clench them. I’ve got a dolly and a few copper roves that your welcome to but they’re probably too large for your dinghy.
Good luck with the repair. I’m sure that is a good timber merchant or woodworker will be able to identify the wood that was used. The Association might be able to help too.
Where in the country are you (and /or the boat) located?...
So I need to find an old school shipwright to do this.
The hunt begins ?
We are in Worcester, kind of between Birmingham and Bristol on M5Where in the country are you (and /or the boat) located?
OK. T Nielsen at Gloucester might be interested / able to help. Well known trad boatyard.We are in Worcester, kind of between Birmingham and Bristol on M5
That's a shame. Bit I did take one look at the photo and thought - "hope that wasn't towed far".She has been fully restored by her previous owner. However as you say they are a busy little craft and Richard ,(previous owner) is now 80 so decided to let her go.
No need for old school, just someone who is trained in wooden boat restoration (we train both young and oldish). To add to @john_morris_uk comments; depending on the plank thickness you might not need to steam as the (relatively thin) plank should bend and edge set. It is unlikely that you will replace a full plank therefore you will also need to be able to scarf the new plank and the existing ones (in-situ). As it’s clinker built you can add any repaired ribs afterwards, but if there are a number you should do them alternatively. You will need to steam any ribs and cut them with the grain in the correct orientation. If the hull shape has altered due to the way the boat has been stored you “may” need to make molds in order to keep her in shape.Hi John,
Thanks so much for the info. Much appreciated.
The hunt begins ?
