winsbury
The modern lubrication requirements of a 1986 diesel BUKH DV20 engine and gearbox are perplexing... searching these forums and reading the manuals, wiki and https://coxengineering.sharepoint.com/Pages/Oilforyachtengines.aspx etc., have not helped much so here's the thinking so far:
Bottom line is which is the right oil to put into the engine and gearbox of my aged engine to give it maximum life ?
- modern (red) diesel has virtually no sulphur content compared to fuel which was around in 1986.
- modern high performance and (semi)synthetic oils are very bad for old engines particularly low temperature direct cooled non-turbo ones but classic oils were intended for use with high fuel sulphur content .
- Adding Fuel Set helps disperse water to avoid the dreaded bug, but it is not clear if it adds any sulphur or equivalent compounds.
- It is still possible to find the obsolete CC and CD grade oils as specified in the original manual, but the chemistry is at loggerheads with modern fuel.
