PacketRat
I'd be interested for views on bilge pumps.
The outlet for my bilge pump used to be in the transom. Having fitted a new aft bulkhead, I'd prefer not to cut through it. Simplest solution would be to drain into the cockpit, although it could equally easily drain onto the side deck through the cockpit coaming.
Conscious of the fact that my off soundings sailing experience is nil, I'm a bit wary about holding an opinion that the bilge pump is really only a convenience for keeping the bilges dry. For emergency use I'm favouring the frightened skipper with a bucket method.
The cockpit is half the original size with double the drainage capacity. I don't rate wet feet as an issue, so why drain overboard? Am I missing something?
Comments would be appreciated.
/forums/images/graemlins/smile.gif Robin.
