savageseadog
1) They are inserted from the leech and held in place by a strap with velcro sewn on which pushes in alongside the batten and holds on velcro sewn into the pocket. I've recently come across two other types.
2) The batten inserts from the leech and engages with elastic sewn into the end of the pocket. The batten when inserted is pressed against the elastic and the outer end is manipulated into a sewn cap on the leech
3) Batten is inserted from the inner end of the pocket towards the leech.
All the batten pockets I've come across are the type 1. They can and do shake out if the velcro tab isn't properly secured and can be hard to undo ib the pull out tab is pushed completely in.
I'm not sure about the others. I do know that the elastic in the type 2 does deteriorate.
