Any Perkins mechanics for advice
Neptune 19
18 May 2020
Hi I have a single perkins 4236 M90 the engine is overheating even on low revs it stays at 100. I put new impeller in still same. I found the fresh water inlet to be blocked I cleaned it out still no improvement. when I start the engine and leave the heather tank cap off im getting back blow from the coolant. is this a head gasket problem or is their something else I can try. If it is head gasket have you got a rough price. Thanks for any advice.
38mess
9 Apr 2019
All over the shop
Is that 100f? If so I would say it's fine. Are you getting blowback with the coolant cap on through the overflow pipe? Have you a white sludge in the coolant tank? Any sign of oily presence in the coolant.
Neptune 19
18 May 2020
yeah theres small amount of oil floating on the top of it
Rappey
13 Dec 2019
I do beg your pardon, but I need to check this. I'm pretty sure it's 40c
If its seawater cooled then it will run around 60c or less (cant remember the exact figures) as salt water starts to crystalises above 60C ?
Fresh water cooled runs around 88c.
38mess
9 Apr 2019
All over the shop
It's fresh water cooled, I sit in front of the temperature gauge 12 hours a day before the lockdown and I can't remember. I'll nip down the boat tomorrow, I have a little white paint mark on the correct temperature
Rappey
13 Dec 2019
If it is only running at 40c then it could have a failed thermostat or not even got one?
And my appologies to Neptune19 for running a little off his topic .
