Rappey
Doesn't keep enough gorillas busy!logical direction for americas cup
No it isnt a sailing vessel any more than kitesurfing is a sailing vessel. But does the label matter? Its an interesting idea and as usual I end up wondering where the French obsession with boats / water / sailing / kites comes from.
But what is the definition of a "sail" If I attach 2 huge goods parachutes to the bow and get them up, am I sailing or been dragged? . I would only be able to go downwind + or - a few degrees.ColRegs 'Rule 3
. . . (c) The term “sailing vessel” means any vessel under sail provided that propelling machinery, if fitted, is not being used.'
Seems to me that it straightforwardly meets that definition.
But what is the definition of a "sail" If I attach 2 huge goods parachutes to the bow and get them up, am I sailing or been dragged? . I would only be able to go downwind + or - a few degrees.View attachment 128021
I just thought that there would be a definition of what constitutes a sail. Playing the devils advocate here., if that parachute was on a boat in a race it could in theory be let out on a 100mt. line and give it a 100 Mt. advantage. I know nothing about racing rules so it might be a moot point. I've worked enough with legal types to know if you can stretch the definition of something some smart bottomed legal eagle will find a way.In my view they would obviously be sails.
Why wouldn't they be? What's the difference between that and a spinnaker, apart from the length of the running rigging?
All any of our sails do is drag us along. All that changes are their shapes, and the arrangements of sticks and strings by which their 'drag' pulls the boat along.
One is attached to a mast or spar, the other is not ?? What's the difference between that and a spinnaker, apart from the length of the running rigging?
That's how I would interpret the definition. A sail is defined as "a shaped piece of material extended on the rigging of a vessel so as to catch the wind and cause it to propel the vessel through the water" that must be connected to a part of the vessel ( mast or fixed rigging. ) with rigging not longer than is necessary to attach it to the said vessel safely edit : at at least one point of contact.One is attached to a mast or spar, the other is not ?
That is because this is a rather low quality render, not a photo of an actual vessel.Interesting that the water is flat, almost glassy - no indication of wind at all.
I was hoping to get 2 pedants to take the hook and run with it . I didn't envisage I would be one of them.There is nothing saying the rigging has to be rigid, or of any particular length. The string is as much the rigging as is the sticks (which is why it is called running rigging and standing rigging).
I don't understand why you have a problem with this, or why you are clutching at straws and inventing your own definitions to avoid the obvious conclusion.
That's where I would have gone if I had continued ,probably not as well put as you though. I was trying to say ,as the devils advocate, that some clever dick would let out a 'chute on 1 or 2 hundred mts of line to gain an advantage in a race. Highly competitive sports will use any nuance of term to its advantage. The last Sydney to Hobart race proves that . An objection was upheld when a boat wasn't in radio contact for a period of time. I would have thought that wouldn't alter the result but someone scoured the rules to gain an advantage.This is a fascinating debate.
Foremost, I'm more fascinated by the technology and always like ideas that challenge limits and know-how.
Second, I'm not sure dictionary definitions are too applicable to the issue. I understand their utility, but in any advanced-level research or debate, regardless of subject or field, dictionary definitions in certain contexts generally became increasingly fallible. Language has always been as much of a benefit as a hurdle, as have ideas and principles. The obvious example is hull speed, which is clearly a solid mathematical principle, but isn't quite as definite as it was once held to be.
When combining these aspects - the peculiarities of language and the aging and applicability of ideas - more questions will emerge such as "is this a vessel?" and "If so, does it have a hull?" That could easily descend into "what's a hull?" and so on. I think the key to appreciate such ideas as best as possible, is to know that change is always active, but the relationship between cause and effect can be complicated - e.g. does technology change language (e.g. the 747 being a "Jumbo Jet"), or does language change technology (e.g. "Is this boat?"). If approaching the issue from these angles, I think these ideas really become valuable to everyone regardless of their opinions/positions.
