4mm Copper compression pipe
StefanSG
10 Feb 2021
Hi just spent a small fortune on all the necessary pipes for my Eberspacher D3L fuel connections, thinking that there was a 4mm copper connection for the fuel inlet on the base of the heater, just found out its a compression fitting looks like 4mm. Can anyone supply me with a female compression nut, a 2" piece of copper pipe with the flares on either end and an olive and the female nut in the middle ? Will pay what you want and postage.
StefanSG
10 Feb 2021
Thanks Ronsurf, had to buy an Eberspacher compression connection, waiting on that, but all sorted on microbore, thanks
