The Q
50 miles in 24 hours sound easy?
Should I add there are three bridges, which means taking your mast down 4 times (two bridges are close to each other you paddle between).
Should I also add the narrowest parts of the rivers are only about 50ft wide and the race is open to boats from 14ft to 40ft.
That sounds a little more difficult..
The is the 3 Rivers Race, on the Norfolk Broads, this year will be the 61st running of the event, 28th /29th May (start times normally from 11:00 to about 12:30) a week earlier than usual due to the Queens anniversary, the record of the fastest passage is about 8 hours , the worst only 13 or so boats finished. up to 150 entries normally just over the 100.
The Course is from Horning Sailing Club , you have to go these turning points in any order then return to the club.
Just before Ludham bridge without going under the bridge.
Into South Walsham Broad going round a mark.
To Below Acle bridge , in a normal year that means to the Stracey Arms Mill, this leg may be shortened if there is light wind.
To the top of Hickling Broad where normally I'll be counting you all past..
You choose the way to go round the rivers are tidal, getting the tides right is everything..
So if you have a boat of less than 4ft draft ( or lifting in use) and fancy racing in the third toughest mass participation event in the UK (according to a newspaper) .
Entry forms and further details are here... Home (3rr.uk)
Any questions please ask..
