Best way to make this connection?
ridgy
26 Jan 2003
North West
Thinking inline crimps with a couple of layers of heat shrink but wondering about UV resistance.
Stemar
12 Sep 2001
While I agree that an internal connection would be a much better solution, assuming it isn't practicable, I'd be inlined to slip some small shrink wrap over the wires and a bigger bit over the outer and solder them. Shrink the little wraps over the solder joint and the big one over everything.
If it's really cheap and nasty, it's possible the wire might be aluminium, and good luck with soldering that, in which case I'd use heat-shrink crimp connectors, plus more heat-shrink as above.
I get Refueler's argument, but a solder connection's easy enough to undo.
justanothersailboat
2 Aug 2021
I wouldn't, personally, worry about it not having an internal connection. Many models of the new LED navigation lights are fully sealed and potted right down to the wire tail. There's no realistic prospect of inspecting inside them, but they ought to last very well (and most do). An internal connection would presumably have terminals or something and become a point of failure.
I'd just use heatshrink crimps inside an outer heatshrink tube. (I did exactly that, when I replaced all my nav lights with LEDs that came with wire tails). I think they're more robust and sealed than solder joints. This is realistically not going to get disconnected very often, losing a bit of the tail when you do is no big deal. Often the tail is long enough that you can get the join inside the cable channel of the mast - you can stagger the two wires' crimps to reduce bulk, at the expense of using up a bit more of the tail.
Refueler
13 Sep 2008
Far away from hooray henrys
Sorry, those connectors are absolute rubbish.
I have to agree ... I watched a video of them - seemed so easy and good .... till they get in your hands and you try it yourself ...
I had a simple RC motor lead to extension to make ... after 4 connectors failed to make secure joints ... I gave up.
I have a big boxfull of them sitting on the side now ...
For something at the mast head that is not easy to get to if it goes wrong ... I prefer corrosion proof plug / socket or hardwired joint ..
PaulRainbow
16 May 2016
Suffolk
One of my customers used them to join the masthead lights wiring after having the mast off. They looked tidy, but when pulled the wires heat shrink stretched until it broke, revealing wires with no solder on them, they were just held together with the glue and heat shrink.
A better option where this type of connection is suitable would be the ones that you crimp and then heatshrink (glue lined).
Refueler
13 Sep 2008
One of my customers used them to join the masthead lights wiring after having the mast off. They looked tidy, but when pulled the heat shrink stretched until it broke, revealing wires with no solder on them, they were just held together with the glue and heat shrink.
I have a feeling that the heat ones could be used like a crimp - but certainly not where inaccessible for repair !!
But yes - they are bl**** useless ! To think I was going to entrust expensive models to them !!
Stemar
12 Sep 2001
They seem like such a good idea!. I, too, have a boxful that this thread reminded me that I need to bin. The heat-shrink crimp connectors do work, though, provided you use the proper crimping pliers. The ones that double as strippers just don't do it.
st599
9 Jan 2006
If you do replace incandescent with LED,you need to ensure that the colour of the Red and Green filters in the housing matches the LED output. Or you end up with a very dim sidelight.
Refueler
13 Sep 2008
Fine ... but that does not mean LED in older filament based lights are rubbish.
I have replaced filament with standard white LED and the only difference has been usually brighter light ... with very low power draw.
