pcatterall
We are considering fitting an evaporator plate and compressor unit to an existing built in cold box.
Is there a cheaper alternate to the dometic range? I see that there are now Chinese alternatives to the Waeco stand alone chest coolers and wondered if there were kits around as well.
What are those special valves called that allow you to connect and disconnect the gas pipes without loosing gas?
