Tim Good
The quote on the BSS site is "Stainless steel fasteners in aluminium plates or sheets are normally considered safe, whereas aluminium rivets or bolts holding stainless steel parts together is an unwise combination, as there is a practical risk of corrosion"
However I have some 10mm bolts holding a large plate to my aluminium mast. Behind which is my mast furling gear. In each side it is secured with approx 10 hex countersunk bolts screwed into the mast. However many are loose no as the thread has corroded.
Two questions:
1. Is there some substance I can coat the threads with if screw stainless into aluminium to prevent corrosion?
2. For the tapped holes in the mast where the threads have deteriotated what is a good option to avoid re tapping for a larger bolt?
Two questions:
