lpdsn
I've a Harken two-speed electric winch that stopped working last year. There was nothing obvious upon inspection at the time. I've now got around to preparing to tackle it.
Anyway, if anyone else has done similar it would be handy to compare notes. I've fitted wiring to both the faulty winch and a good one to compare voltages. Surprisingly, both +ve terminals on the motor are powered up regardless of which button is pressed, bith on working and faulty winches. The voltages across the motor for the working one are down about 0.75V, which is as I'd expect if it's drawing large currents, but otherwise is no different. So I still don't know what determines which way the motor spins, although that's probably just a side issue.
The electrical connections are as per those shown in the manual at the link below.
http://www.harken.com/uploadedfiles/Product_Support/PDF/46.2STE_HY-08.pdf
There's no current flowing through the motor of the faulty one. Obvious suspicion is that the wiring is burnt out, but curiously there was no smell of burning when it stopped working.
So, anyone got similar experiences of an electric winch failing?
