All_at_Sea
Is this possible, has anyone any experience of trying to remove scratches from perspex. I'm wondering whether they can be polished out?
This might be worth a try
http://www.theultimatefinish.co.uk/...-polish.aspx?gclid=CKO42IXn9rECFYQhtAodyDEANA
In used a polishing mop and G3 Farecla cutting compound followed by polish to finish - basically the same technique as restoring gel coat and it worked a treat on my saloon windows.
Low speed and plenty of lubrication is essential
.... Looking for something useful to do, they cleaned the waterline with tothpaste and toothbrushes .....
I recently bought a bench grinder on eBay. The 'clear' safety eye screen was completely opaque, with embedded rust and cloudy plastic where I guess it had been left in the sun. I cleaned it up using a few grades of wet and dry paper followed by solvol autosol which is a fairly coarse metal polish, followed by T-cut.
I recall it's a good idea to wash the tcut etc off fairly thoroughly as it contains oils which may yellow some plastics?
You can get w&d paper in 2000 or even higher grades now, worth going to the finest grade you can IMHO if you have to sand scratches out, but starting with too fine a grade is just a waste of time.
