ari
Mercruiser \"double beep\", what does it mean?
Boat fitted with Mercruiser 4.3MPI sterndrive engine. It has a warning alarm and when you switch the ignition on it beeps once to let you know it's active and working. The idea of the alarm is that if you get low oil pressure, battery voltage or high water temp it sounds to alert you. (It also has "Smartcraft" which is electronic engine management which shuts the power down to an acceptable amount if it detects a problem).
Last night when out on the boat I started it up fine, headed out the harbour, and about every two minutes it gave a double beep (each beep about 1/2 second). Gauges were reading fine, exactly where they should be. Once we were out I opened her up (I thought it could possible be low battery and maybe more revs would give it more alternator) and watched the guages. Still perfect, boat performing fine, still the double beep every two mins or so.
Stopped at destination (only 10 min run), dropped anchor, shut off engine.
Re started about an hour later. Tried blipping the engine in neutral just to see what happened. Every time the engine peaked (about 3,000prm or so) it would bleep once and stop as the revs dropped.
Set off gently, built up speed, no bleeps, not even the double bleep we had initially on way out. Eased revs up and up, absolutely fine, gauges all fine, no problems. Wound it out to WOT briefly, still perfect.
Back into harbour, no bleeps, no double bleeps, nothing.
Totally mystified by it. It's never bleeped once (apart from ignition on test bleep) in three years of use.
Will check manual (didn't have time last night) but it's on the boat so can't check it till next down there.
Tried to find an online manual to download to see if it said anything but no joy.
Any thoughts or ideas most welcome.
