Oxalic acid: how strong.
pcatterall
2 Aug 2004
Home East Lancashire boat Spain
I have some oxalic acid crystals and want to make up a strong mix but not too strong.
I would like to aim ayt the sort of strength which my rather leather like hands could tolerate for a few seconds provided it was washed off PDQ.
Any ideas? This is for wasing stains from hull and stainless parts.
<<<the sort of strength which my rather leather like hands could tolerate>>>
Have stopped making latex examination gloves, 100 pr for AU$8.00. ?
Also stay upwind if you don't have a respirator or you will have more than your hands dissolving......
then mix a bit of wallpaper paste into the mix and it will spread on the intended area, and not drip off /forums/images/graemlins/laugh.gif
Ah yes!! I'll do what I oughter 'add acid to water'
The point about rubber gloves is sensible of course but I have had a couple of nasty experiences where the gloves got a hole I couldnt feel anything until the acid really started to burn and by then it was too late.
It is suphuric acid to which the "add the acid to the water" rule applies but it is also good practice with other strong acids. No problems with oxalic acid but it may be more convenient to add the crystals to hot water. The instructions on the AG Woodcare website, however, are:
Pour 2-4 tablespoons of oxalic acid crystals in a heat resistant glass jar and add one pint hot water.
As far as I can find the solubility of anhydrous oxalic acid is only 90g/litre at 20C, thats 9%, and equates to 126g/litre (say 12½%) for the dihydrate but many recipies suggest it is more soluble.
The main hazard is its toxicity if ingested, it can can be fatal! It is also absorbed through the skin and by that route can affect the kidneys. It is aso an eye irritant.
You must avoid prolonged contact with the skin, washing splashes off promptly, so good gloves are required. They may be nitrile, butyl rubber, neoprene or PVC.
Goggles are a must to protect the eyes.
Make sure all waste is disposed of safely and that any unused material is properly labelled and stored safely.
Has anyone any experience of using oxalic on a painted surface?? I've used it on gelcoat with some success but my latest boat is painted with 2pack acrylic and I'm affeared it might damage it.
Safe sailing
Sparkie
You should not use any acidic cleaners on an enamelled bath as they attack the surface. You sould take care to only use a product labelled as suitable for such surfaces. Acid based cleaners will not, however attack a glazed surface, such as the toilet or wash basin, or plastics but you should nevertheless read the label.
